Why does the car accelerate well at lower speeds, but when it reaches around 110 km/h, it struggles to accelerate further for overtaking? Even on a slight incline, it has difficulty gaining speed.
How is the performance of the 2021 2.0T manual Super Sharp Long Wheelbase Short Overhang High Roof model? I often carry cargo for long-distance trips, so I have certain speed requirements. How fast can it go under normal driving conditions? Is it good for acceleration and overtaking? Thanks.
What is the top speed of your Eclipse Cross? When I floor the accelerator, the highest I can reach is 160 km/h, and it drops to 140 km/h on slight inclines.
When starting, there's a noticeable vibration, but the higher the speed, the less the vibration. There's no vibration when coasting, but as soon as you accelerate, you feel it, especially at lower speeds. Why is that? There's no unusual noise. I've already replaced the left half axle, engine mounts, and recently changed the tires and ignition coils. The repair shop says it's an issue with the transmission and it needs repairs. Is that true? 😮💨
4Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
5How does the 1.5 Cetus perform on long-distance, high-speed drives? Is the power sufficient, and does it struggle to reach 120 km/h?
6Why does the car accelerate well at lower speeds, but when it reaches around 110 km/h, it struggles to accelerate further for overtaking? Even on a slight incline, it has difficulty gaining speed.
7I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
8Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
9When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
10When my car reaches a speed of 110, the steering wheel starts to shake. What's going on with that?
