نايف عاطف
2024-02-26 14:49
The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
عبد الرحمن محمد
عبد الرحمن محمد2024-03-06 18:04
The wiring harness under the front passenger seat is a bit loose; just plug it back in and it should be fine.
Hey folks, my emission warning light was on for a few days, then it went off. Anyone else had the same issue? What could be the reason?
It's really important to have a nearby service station before buying a car; I've really felt this in the past few days!
Why does the air conditioning compressor keep making noise for a few minutes after parking and locking the car? What could be the reason?
There have been heavy rains these past few days, and the driver's side is leaking, with the A-pillar being wet. Could it be that the sunroof is blocked? Or is there another reason?
Hello fellow car enthusiasts, I own a Patrol Y62. A few days ago, while driving, the lower ball joint on the left rear wheel suddenly broke. Do you know what might have caused this?
Have you ever experienced driving 10 kilometers every day and suddenly noticing a time difference of exactly one hour, without any minute discrepancy? What could be the reason for this?
The 2014 model with a 3.5L engine shows the engine warning light and exhaust system fault light at 100,000 km. The sensors have been replaced, but after a while, the lights come on again. Does anyone know what the reason might be? Generally, the lights only come on when driving at high speeds. Could it be related to the Evans waterless coolant that was changed a few years ago at the 4S shop?
2015 Red Label manual Xiao Er suddenly lost all power and the screen went black while driving, and it wouldn't start. After two or three minutes, it was fine again. Has any fellow car enthusiast experienced the same situation?
While driving, the central control screen suddenly went black, then restarted after two to three minutes, followed by a "pop" sound. Any ideas?
GAC GAC GA8
GAC GA8TBDGasoline
