The GA8 often has trouble starting and requires several attempts. How can this issue be resolved?
There is power in the T60 pickup truck, but sometimes it takes several attempts to start. What could be the reason for this?
MG GS, with over 60,000 km, recently having trouble starting the car. It requires several attempts to start. Once started, five or six warning lights come on, and when pressing the accelerator, the car doesn't move, can't go over 10 km/h. It often needs to be turned off or re-shifted. Sometimes while driving, pressing the accelerator doesn't speed up the car, but the engine sounds like it's in neutral. It also jerks when moving. Local repair shops are hesitant to fix it, and the 4S shop is too far away. I'm worried the car won't accelerate on the road, which could lead to an accident. Seeking help.
4When driving, if the car suddenly doesn't respond when you press the accelerator, and even flooring it doesn't increase the RPM, but releasing and pressing it again solves the issue, this could be a problem. When starting on a steep slope, if the car feels powerless and sometimes can't climb, requiring several attempts to increase RPM, there might be an issue to address.
5When the power tailgate of the 2018 Koleos only opens a crack and requires a second press to open fully, but closes in one go, how can this issue be resolved?
6In the past month or two, my Vitara has experienced difficulty starting on two occasions. It takes several attempts to get the engine running. What could be the reason?
7What could be causing the severe idling vibration in the x95? It's at 5.5 kilometers. How can I resolve this issue?
8Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
9Is anyone experiencing issues with starting their 2017 Jeep Compass automatic Home Edition in the morning? It feels like the battery is dead and requires multiple attempts to start. How do you solve this problem?
10Have you ever experienced the second generation MG6 occasionally requiring a second attempt to start? Are there any warning lights appearing? What is the situation?
