Is there anyone with a 2020 GA8 experiencing occasional engine shaking and exhaust fault codes? How did you solve the problem?
Has anyone replaced the central control system on cars after August 2019? If you removed the original system, did it trigger an engine fault code? How did you resolve it?
My car failed to start twice, and various fault codes appeared. The diagnosis showed that the ambient light fuse was blown. Have you guys experienced this? How did you solve it?
4Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
5Is it a problem if my GAC GS5 occasionally shows error codes? How can I fix it?
6Engine shows fault code, acceleration is weak, what could be the reason?
7MG ZS intermittent engine fault code. It disappears and then reappears, how to deal with it?
8How to handle the occasional engine warning light in the 2020 MG ZS?
9Hey guys, anyone experienced issues with the VVT wheel sticking on the 2020 Jetour X70 exhaust? How did you solve it?
10What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
