علي ذكي
2023-08-18 07:30
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
Comments( 6 )
محمد حمدان
محمد حمدان2024-01-13 07:53
This seems to be a common issue...
شمس محمد
شمس محمد2023-12-30 02:30
Just turn off the fuel economy mode and switch to normal mode.
نايف عامر
نايف عامر2023-08-23 21:13
My car jerks a lot when shifting from 1st to 2nd gear.
عبدالرحمن أسد
عبدالرحمن أسد2023-08-20 16:52
I didn't pass this question.
عبدالرحمن قاسم
عبدالرحمن قاسم2023-08-18 16:46
Smooth, just occasionally there's a slight jerk when shifting from third to fourth. Otherwise, everything is pretty smooth.
محمد سعد
محمد سعد2023-08-18 16:22
I don't have this problem.
What viscosity of engine oil do you use for your new Mazda5? What's your fuel consumption? And does your transmission shift from 1st to 2nd or 2nd to 3rd gear smoothly? I'm experiencing some jerking.
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
I have a question for everyone. I have a 2009 Honda City automatic 1.5. There's some jerkiness when shifting from 1st to 2nd gear, but it's better from 2nd to 3rd. Since it's a used car, I'm not sure how many kilometers it's been driven. Can changing the transmission oil solve this issue? How many liters are needed for a gravity change of the transmission oil?
What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
Is there anyone experiencing a harsh jolt when shifting from 1st to 2nd gear, along with some strange noises? I'd like to ask for solutions. Mine is a 2019 X95. Thanks!
Do any of you fellow car enthusiasts feel that the 1st and 2nd gears are noticeably jerky?
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
GAC GAC GA8
GAC GA8TBDGasoline
