I feel like the high beam is aiming a bit high. Is there a switch in the car to adjust it? I've looked around but couldn't find anything.
I feel like the stock steering wheel position of the March is too high, and I want to adjust it lower but can't find the mechanism. Where is it located?
What's the fuel consumption for your 2.4 NA engine? Mine is around 14, is that normal? It feels a bit high.
4How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
5Has anyone modified their headlights? The high beams feel so weak, it's like there's no difference whether they're on or off. [Shocked]
6How can I adjust the high and low beam headlights inside the car?
7The low beam is a bit low. Which setting is appropriate to adjust it to?
8I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
9For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
10Is it still possible to buy the 24 model with the performance package? I've looked around and couldn't find any with the option.
