How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
How many liters and what grade of oil is needed for an oil change?
How many liters of oil does a 1.5T engine need to be changed? Is it easy to do it yourself?
How many liters of transmission oil are needed?
4How many liters of oil does a Smart car need for an oil change?
5How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
6How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
7How many liters of oil does a Mazda 2 automatic transmission take for a gravity oil change?
8Has anyone changed their transmission oil? How many liters did you use, and did you do a gravity change or a complete flush?
9Has anyone changed their transmission fluid? How many liters did you use? Did you do a gravity change or a full cycle change???
10How many liters of engine oil? How many liters of transmission oil?
