Hey everyone, when you auto park your new GA8 and then start it again, do you hear a creaking sound? I haven't noticed that with other cars. Also, sometimes when braking automatically and the speed is close to 0, I feel the brake pedal jitter downward with a continuous noise. It's happened twice in 7000 kilometers. It doesn't affect the use, but I'm curious. Could this be a sign of a potential future issue?
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
4I want to get a new car for my wife. She's currently driving an IS. After looking at a lot of cars, only the G70 shooting brake seems relatively pleasing. Here are my main concerns: 1. A friend mentioned that there's not much difference between the two cars, and the IS might be slightly better, so it may not be significant. 2. Recently, many car companies are offering discounts and promotions, but the manufacturer currently shows no sign of doing so. 3. Both cars require ordering and production scheduling, which means a long waiting time, making it awkward. 4. Since it's all about ordering and production scheduling, the options and configurations are not flexible enough. 5. I'm worried about their sales and the potential of dealership closures. Have any other car owners faced similar awkward issues? [Facepalm]
5Seeking advice from fellow car owners: 1. Is it normal to feel a slight vibration in the steering wheel when the air conditioning is on? 2. When using the standard + B mode, there's almost no brake dive, but when the auto hold is activated, the brake dive is quite noticeable. Do you experience this too?
6When starting on a slope with a temporary license plate and using auto hold at a gate, the car tends to roll back when pressing the accelerator after the gate opens. Have any experienced car owners encountered this issue? How do you solve it? Should I use the electronic handbrake? PS. I didn't have this problem with my previous Volkswagen Golf. When stopped on a slope, I just kept the brake pressed and it moved forward when I pressed the accelerator, without rolling back.
