منصور عبدالرحمن
2023-02-21 13:07
Fellow car enthusiasts, does your car take a long time to heat up? It seems like I need to drive 8 or 9 kilometers before the water temperature is sufficient, otherwise I'm hesitant to turn on the heater. If the car is warmed up for a while, it's a bit better. Do you guys have any solutions? 🙏🙏
حسين رضوان
حسين رضوان2023-06-14 00:33
When driving at high speeds, does the water temperature drop? If so, you might need to replace the thermostat, as it could be stuck in an open position, causing the water temperature to rise slowly.
محمد ربيع
محمد ربيع2023-05-23 12:19
Could you provide more context or details about the situation? I'll be happy to help with the translation!
علي أرسلان
علي أرسلان2023-02-23 08:30
I have the same issue as you, and I'm preparing to replace the fan module now.
منصور عبدالرحمن
منصور عبدالرحمن2023-02-22 15:21
Coolant isn't low, not sure what the reason is [what].
عبدالرحمن يزيد
عبدالرحمن يزيد2023-02-21 18:04
Is the coolant sufficient?
The Volkswagen Lavida charges very slowly, and it charges even slower when the car is warmed up.
The engine temperature is normal, but the air from the heater is not warm.
Car enthusiasts, when I'm idling or driving, there's a muffled noise, and the acceleration doesn't pick up. What could be the issue? Looking for some guidance from fellow car enthusiasts. 🙏
When the car starts, the ESP warning and engine fault warning appear, and it can't shift gears. It needs to warm up for half an hour before it can move. How can I solve this?
When starting a cold car, there's a whirring noise but it stops when the car warms up. What could be the issue? If any experts know, please let me know. 🙏
Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
At 45,000 kilometers, there's no issue with a heavy throttle, and there's no problem with a light throttle either. But when I press the throttle slightly harder, the issue arises, especially noticeable at 2000 RPM. There's no such problem when the car is cold, but once the water temperature reaches two bars, it comes back. It's really frustrating. Any advice? 🙏🙏🙏
My Scirocco feels jerky when shifting in S mode. At half throttle, it reaches 4000 RPM and reports an engine fault that needs repair. The EPC light is on, and it mentions something about oil pressure and the engine's maximum speed at 4000 RPM. What's going on, experts? Once I restart the car, everything seems fine (after the car is warmed up, with both water and oil temperatures up to normal levels).
What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
GAC GAC GA8
GAC GA8TBDGasoline
