Does your engine cylinder head leak oil?
Why is the clutch master cylinder of my Haval leaking oil after running less than 20,000 kilometers?
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
4Are there oil leaks in the engines of the three generations of YUEXIANG?
5Does the V40 engine leak oil? Thanks.
6Is it possible for there to be an oil leak at the connection between the transmission and the engine?
7What are the solutions for an oil leak from the hood of the Xiaoyan engine?
817 Leading Edition... 220,000 km driven. The engine cylinder head is damaged, causing water leakage. Has any other owner encountered the same issue?
9How to deal with a transmission oil leak? Does it affect daily driving?
10The engine warning light is on, indicating an oil leak. I changed the oil 4 days ago using 5-30w. What's going on? Does anyone know?
