Can the GA8 dashboard change themes?
How to change the dashboard language of a C30 to Chinese?
The GA8 often has trouble starting and requires several attempts. How can this issue be resolved?
4How many liters of transmission oil does the GA8 need to change? Should it be by gravity?
5Can the Ga8 be ordered with a manual transmission?
6What dashcam is everyone installing on the Trumpchi GA8? Can any expert recommend one?
7Is there any modification for the music system of the GA8? Can you recommend a set?
8How to adjust the fuel consumption display on the dashboard? It recently changed to something else, showing 33km like that. How can I change it back?
9How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
10Is there a 2020 GA8 available?
