خالد نعيم
2024-02-15 15:41
Why does the specification on my tire sidewall say 215/50/17 instead of 205/50/16? The current tires on the wheels are 215/55/17. It's a 2016 automatic comfort model produced in 2019.
علي سعد
علي سعد2024-02-26 13:42
The low configuration one is 16, right?
I'm getting ready to change my tires. Has anyone switched to 225/55/17? Are there significant differences in comfort and handling?
Should I choose the Haval or bite the bullet and go for the Explorer? I'm 40, work in a stable job, don't smoke or drink, and love driving. Whenever I go out with friends, I'm the one driving, and I enjoy it even if it's a five or six-hour drive. I don't feel tired. I usually commute alone, about 20 kilometers round trip. Rationally, I should prioritize family and choose the Haval. It's not much fun to drive, but it's cheaper and comfortable for the family. But there's a little devil on my shoulder saying: Go for the Explorer, there aren't many days left to indulge in what you love. Most of the time, you're driving alone, so why not get something you truly enjoy? You only go on trips a few times a year. Brothers, any advice?
If you want to modify your tires without changing the 17-inch diameter, you can consider changing the tire's width or profile. You can opt for a wider tire for better grip or a different profile for improved performance. Just make sure the new tires fit your vehicle's specifications and don't affect the overall driving experience. It's always a good idea to consult with a professional or refer to your vehicle's manual for recommendations.
Hi everyone, I want to ask about the 2024 Cayenne. When I bought the car, there were no 21-inch wheels available, so I got the original 20-inch ones. Now I'm planning to change them. Should I go for the 20-inch bird's nest wheels or directly switch to 21-inch tires and wheels? I'm not very familiar with this. I've heard that 21-inch wheels might affect comfort and increase noise. A friend who repairs cars also says I don't need 21-inch wheels, but I'm worried I might regret sticking with 20-inch. Any advice?
GAC GAC GA6
GAC GA6TBDGasoline
