حسين محملة
2023-10-26 04:41
Why does the right front wheel of my 2019 GA6 get about ten degrees hotter than the other three wheels after driving for a while? When I touch the hub, the temperature difference is quite noticeable.
أحمد رحمن
أحمد رحمن2023-11-27 10:52
The engine is on the right side, so of course, it will be higher than the other three.
عبدالله شفيع
عبدالله شفيع2023-10-30 23:43
My right front tire temperature is also a few degrees higher.
عمر طيب
عمر طيب2023-10-29 18:59
It's normal for the front wheels, which are responsible for driving and steering, to be warmer than the rear wheels. The right front wheel being hotter than the left front wheel is said to be due to engine heat radiation. I'm not sure if that's indeed the case.
محمد جلال الدين
محمد جلال الدين2023-10-27 14:34
Engine impact issues.
علي سعد
علي سعد2023-10-26 09:49
Go check if there's a problem with the brake pads.
How to solve the seal problem? Has anyone else encountered this? It drifts to the right quite severely. Kugou can't open. There's a strange smell from the air conditioning. The steering wheel vibrates a lot, and in winter, the range is only 60-65% of what's advertised.
Are you asking if the fuel consumption of the Haval H6 is high? My car's fuel consumption is quite high right now. It takes about 20 liters per 100 km when starting and turning. I've already spent 700 yuan on fuel in less than a month. [Crying]
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Is there any car owner experiencing a noise from the right rear wheel? When the temperature is low, there's a squeaking sound when going over speed bumps. There's no abnormality during normal driving, and it doesn't make noise on bumpy roads. The shock absorber isn't leaking either. The car is only three years old, so it shouldn't be the stabilizer bar bushing issue, plus the sound doesn't seem like it's from the stabilizer bar bushing.
Apart from the fabric seats, plastic materials, and the 360-degree camera, the features of the 450,000 model are quite similar to the 510,000 model, right? I feel like the 450,000 model offers better value for money compared to the 510,000 one.
Porsche's contrast stitching seats refer to a design feature where the stitching on the car seats is in a different color than the main upholstery. This creates a striking visual effect and adds a touch of luxury and customization to the vehicle's interior.
Today, while washing my car, I noticed that all the left side windows have markings, but the three right rear windows don't. What's going on here? Did I accidentally buy a damaged car? I own a 2021 Subaru Outback flagship model.
Is it normal for a 2014 Peugeot 2008 1.6 automatic to have the engine temperature rise very slowly, taking over ten minutes to reach 70 degrees? Could it be that the engine oil is too thick?
GAC GAC GA6
GAC GA6TBDGasoline
