When I put my 2019 GA6 in drive, there's a motor sound like a "squeak," but it doesn't happen in reverse. Is this normal, and do you have any ideas about it?
When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
Hey guys, I have a question about the 2006 Peugeot 206 1.6 with the semi-automatic transmission. When I put it in reverse gear, the reverse lights don't come on. What could be the issue?
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
4I have a 2019 GS5 Elite version. Sometimes the central control screen doesn't power on, but the air conditioning works fine. The reverse radar is not usable, and the central control screen doesn't light up. Does anyone know why this is happening or has anyone else encountered this issue?
5Is it normal to hear a squeaking sound from the engine while idling when sitting in the cabin?
6After turning the key, it doesn't spring back, and there is a squeaking sound when shifting gears. What could be the issue?
7I have a 2019 Jeep Compass 1.4T. When I put it in reverse and give it gas, there's a "thud" sound sometimes, but not always. Does anyone know what's going on? I checked with a mechanic, and they said it's normal for a dry dual-clutch transmission. Can anyone confirm this? Thanks.
8When I put my 2019 GA6 in drive, there's a motor sound like a "squeak," but it doesn't happen in reverse. Is this normal, and do you have any ideas about it?
9Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
10When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
