عمر قابوس
2023-06-01 10:44
What should I do if there's rust inside the wheel?
حسن طموح
حسن طموح2024-07-18 09:25
Solutions for dealing with rust inside the wheels include: 1. Rust removal: Use sandpaper or a wire brush to gently scrub the rusted areas and remove rust. Then wipe clean with a cloth. 2. Apply anti-rust agent: After cleaning off the rust, apply a specialized anti-rust agent to form a protective layer to prevent further rusting. 3. Check the brake system: Rust can affect brake performance, so check if the brake components are functioning properly. Repair or replace them if damaged. 4. Keep dry: Avoid parking the vehicle in damp environments for long periods and clean the wheels promptly after rain. 5. Regular maintenance: Regularly maintain the vehicle, including inspecting and servicing the wheels.
