حسن أحمد
2024-11-22 21:45
The low beam height adjustment and rearview mirror adjustment on the 2015 model are not responding, but the mirrors fold automatically when the car is locked. The start-stop and anti-slip functions are working fine. Additionally, the car's infotainment screen suddenly goes black and restarts when driving at high speed. Has anyone else experienced this and found a solution?
The heated rearview mirror isn't working, but the electric adjustment is fine. I've been to several repair shops, and they all say I need to replace the base, which costs over 2000 for an original one. Any experts here who can give some advice? Thanks!
How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
Can the low beam headlights of the 2010 Peugeot 207 be adjusted for height?
Can you adjust the angle of the rearview mirror on the Geely? It feels like it's tilting too low... Or can it be set to tilt on one side only?
How to adjust the low beam height on the GAC Trumpchi GS7?
How can I adjust the low beam height on my H7? They're too low. Also, how do I use the headlight cleaning system? Waiting for some advice from fellow car enthusiasts. 🙏
How do I adjust the low beam height on the Hongqi H7? It's too low. Also, how do I use the headlight washer? Waiting online for help from fellow car enthusiasts. 🙏
Is the automatic anti-glare function for the exterior rearview mirrors on all Ford models only available on the driver's side, but not on the right side?
Hello everyone, for those who bought the Jetta VS7 Automatic Glory Edition, do the features like anti-glare rearview mirror, electric tailgate, magic box, hydraulic strut for the electric tailgate, and welcome lights require an additional optional package costing four thousand? Appreciate any sincere advice from you all.
GAC GAC GA6
GAC GA6TBDGasoline
