سعود عيسى
2020-10-08 11:26
My GA6 used to automatically unlock when the key was near the door and lock when the key moved away. Now it's not working. Any suggestions?
Comments( 14 )
فهد جم
فهد جم2023-12-01 16:01
Try replacing the battery on Pinduoduo.
تميمي علي
تميمي علي2023-11-28 21:43
The key battery is charged; it's the door lock sensor that's malfunctioning.
تميمي علي
تميمي علي2023-11-28 21:41
I went to the dealership today. It wasn't a battery issue; they checked and found it was a software problem. At the dealership, they just reconnected it to the computer and reset it, and it was fine.
نايف لبيب
نايف لبيب2023-11-27 14:17
How to open the door if it doesn't unlock automatically?
أحمد مراد
أحمد مراد2023-11-21 10:36
Try changing the battery, and also make sure not to place it next to your phone as it might interfere with the signal transmission.
خالد وهاب
خالد وهاب2023-11-21 03:42
I've experienced that too. It's because the key fob battery is running low. Just replace the key fob battery, and it should work fine.
عبدالرحمن زبيدي
عبدالرحمن زبيدي2023-11-20 21:58
Mine is like that too.
محمد زياد
محمد زياد2023-06-24 02:12
My keyless entry is not working.
عمر عبد المجيد
عمر عبد المجيد2023-06-13 22:38
Probably the key's battery is dead.
عبد العزيز محمد
عبد العزيز محمد2023-06-13 16:44
Open the trunk to check if the plug has come loose.
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
If the unlock or lock light is not working, how to fix it?
The car key doesn't automatically lock or unlock when it's nearby. Does anyone know why?
Does the 2019 model of the Ga6 automatically lock the doors while driving?
It seems that the 2011 Nissan Sunny doesn't have an engine immobilizer. I can just use a mechanical key to unlock the door and drive away.
Does the luxury version have an automatic lock function? I tried it today, and when I walked away without pressing the remote key or car door lock, it didn't lock automatically. How about you guys? 😊
Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
GAC GAC GA6
GAC GA6AED 112,900Gasoline
