Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
Comments( 11 )
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
Hello everyone, is it normal for my 2013 Mazda 5 automatic to have a noticeable jerk when shifting from first to second gear, while other gears aren't as obvious?
4I want to ask if there is any jerkiness when shifting gears in the GA6.
5I want to ask everyone, I have a 2022 automatic 86. When shifting from a lower gear to a higher one, there's a bit of a jerking sensation. Is this normal?
6Is the MG car lacking power when going uphill? Does it jerk in second gear? Is this common?
7What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
8When slowly accelerating at low speeds, the V60 B4 2024 model experiences noticeable jerking and dragging.
9Does your Jetta automatic also have a noticeable jerk when shifting gears?
10Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
