I want to ask if there is any jerkiness when shifting gears in the GA6.
There is a bit of a jerky feeling when shifting gears, and it lacks power when accelerating. What's going on? I've already cleaned the fuel system and replaced the transmission assembly. #JetourX95
I want to ask about my 2019 Changan Yuexiang automatic. When I start the car cold and shift gears, it takes about 2000 RPM to change gears, like the clutch is slipping. Once the engine warms up, the shifting is normal. Do other car owners experience the same issue?
The gear shifting feels jerky. When going downhill, just a tap on the brake slows it down to the minimum speed. The fuel consumption is too high, basically 11 liters in the city.
4Hey guys, I want to ask if it's normal for my 2006 1.6 automatic Peugeot 206 to feel jerky when driving at 40 km/h and 60 km/h in D mode?
5Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
6Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
7Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
8Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
9I want to ask if there is any jerkiness when shifting gears in the GA6.
10I want to ask everyone, I have a 2022 automatic 86. When shifting from a lower gear to a higher one, there's a bit of a jerking sensation. Is this normal?
