فهد ميك
2024-01-16 19:32
I bought the 2022 GAC GA6 in May this year, and the remote key's automatic unlocking function when approaching the vehicle is gone. Does anyone know why?
عبد العزيز مرشد
عبد العزيز مرشد2024-01-17 23:39
Settings, or the battery is dead.
عمر عادل
عمر عادل2024-01-17 14:53
Just turn it off in the settings.
علي قابوس
علي قابوس2024-01-16 22:26
Try adjusting it first, if it doesn't work, replace the remote battery.
نايف حبيب
نايف حبيب2024-01-16 21:04
My screen settings got turned off.
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
My car key no longer has the unlock function. Can any expert provide some guidance? It's a 2017 Roewe RX5.
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
Hey fellow Mazda 5 owners, where can I get a remote key made? Can it have the same functions as the original one?
Does the car have the automatic lock when leaving and automatic unlock when approaching functions? Can the car system meet the needs for daily convenient use?
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
If the remote control function of your Peugeot 307's key is not working, even though the key itself is in good condition, what could be the issue?
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
Hey car enthusiasts, does the rear trunk of the Seltos luxury edition have a remote control function? I see a trunk remote icon on the key fob, but it doesn't work. Thanks!
GAC GAC GA6
GAC GA6TBDGasoline
