How to use the steering wheel buttons on the 2016 GAC GA6? This morning while driving, I accidentally pressed a button on the steering wheel, and the driving settings interface appeared on the small screen in front of the steering wheel. Does anyone know how to bring it up?
No 8AT, no four-wheel drive, I'm so disappointed... Even a four-wheel drive option would be fine. Why not bring in a high-power four-wheel drive? What's the point of introducing this version!
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
What do the buttons on the Arrizo 3 steering wheel mean? 😓
4Do you guys feel that the steering wheel of the 2022 GA6 is a bit heavy? It's much lighter on other cars.
5How do you open the horn button cover on the steering wheel of the 2019 GA6?
6How can I adjust the steering wheel weight on the Tucson L? The steering wheel feels too light and a bit wobbly when driving at high speeds.
7In a 2019 manual vehicle, if the steering wheel buttons suddenly stop working and after resetting and reconfiguring, the buttons still don't respond, what could be the reason?
8Do you all add a steering wheel cover to your 2024 GAC GS8 Fuel version?
9Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
10Why does the steering wheel vibrate while driving?
