How do I change the battery for the 2022 model car key? What type of battery does it use?
What type of engine oil is used for the 2019 model?
The second key hasn't been used for a while. Recently, I took it out and found that the remote doesn't work. I changed the battery, but it still doesn't work. Does anyone know why?
What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
4How do I change the battery for the 2022 model car key? What type of battery does it use?
5I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
6What type of engine oil do you guys use for the 2022 2.5 model?
7How do you use the key to open the windows on the 2022 Kamiq? Thanks.
8What type of fuel does the 2019 model use?
9How much and what type of oil should I use for a Cetus oil change?
10Does the 2022 model come with a Blade Battery? How about the 2021 version?
