فهد قيس
2024-05-03 16:48
Does anyone know the size of the air conditioning filter for the 2019 GAC GA6? I've bought many, but they're all a bit thin. I got one from the store before that fit perfectly. This filter is thicker than the usual ones!
The air conditioning filter for the Volvo C70 is typically located behind the glove compartment. To remove it, you usually need to follow these general steps: 1. Open the glove compartment and empty its contents. 2. Carefully detach the glove compartment by removing screws or clips, depending on the model year. 3. Once removed, you should see the filter cover. Release the clips or screws holding the cover in place. 4. Remove the cover to access the air conditioning filter. 5. Slide out the old filter and replace it with a new one, ensuring it's oriented correctly. 6. Reattach the cover and secure the glove compartment back in place. Make sure to refer to your vehicle's manual for specific instructions, as the process can vary slightly depending on the model year.
I bought a Lavida Pure Electric, but I can't check the battery level on the app or WeChat mini program. I called and consulted customer service online. They were very polite, but no one has resolved the issue. It's been more than ten days now, and I wonder how long this will drag on. Is this really the kind of service Volkswagen offers?
I bought the 2022 GAC GA6 in May this year, and the remote key's automatic unlocking function when approaching the vehicle is gone. Does anyone know why?
Can this car be fitted with 15*7J rims? Or 6.5J ones? Has anyone modified their rims, and what's the largest size you can go up to?
GAC GAC GA6
GAC GA6TBDGasoline
