خالد لاويل
2024-09-18 09:29
I've been following the G80 for a few years now. Has anyone noticed that adding a mild hybrid system to the existing powertrain could make it more competitive? The ES's mild hybrid system really beats other competitors in terms of fuel economy!
سلمان شجاع
سلمان شجاع2024-09-18 20:07
The ES is not a mild hybrid, it's a full hybrid. The failure rate of mild hybrids is too high.
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
Has anyone experienced their mild hybrid system suddenly not working?
It would look better if the license plate was placed on the tailgate, making the tailgate design more attractive, and adding a 48V mild hybrid system.
Choosing between the G80 and the XFL depends on your personal preferences and needs. Here are some things to consider: 1. **Brand and Model**: - G80 generally refers to the Genesis G80, a luxury sedan known for its comfort and advanced technology. - XFL typically refers to the Jaguar XFL, which is the long-wheelbase version of the Jaguar XF, offering more rear-seat space and luxury features. 2. **Performance**: - Consider the engine options and horsepower each model offers. The G80 might offer a more powerful engine, while the XFL might focus on a balanced ride. 3. **Features**: - Look at the features each car offers, like the infotainment system, loudspeakers, safety features, and interior quality. The G80 is known for its tech-savvy features, while the XFL may emphasize luxury and style. 4. **Fuel Economy**: - Check the fuel economy for both. If fuel efficiency is a priority, this might influence your decision. 5. **Comfort and Space**: - If rear-seat space is important, the XFL might have the edge due to its extended wheelbase. 6. **Budget**: - Consider the price and what fits better within your budget, including maintenance costs. Ultimately, test driving both and considering these factors could help make your decision easier.
I've been checking out the 2024 1.4T version of the Superb and want to ask about the actual fuel consumption. Planning to use it for commuting and occasional trips. I'm concerned about fuel economy, especially with city traffic. I'm torn between the Corolla Hybrid and the Superb 1.4T for long-term ownership. Any advice from those who've been down this road?
Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
Is the 48V mild hybrid system in the G90 a BSG or an ISG?
Genesis Genesis G80
Genesis G80AED 154,500 ~ 293,000Gasoline & Petrol
