علي تاج
2024-08-31 22:29
Dear Genesis car owners, have you used the built-in ETC? How's the performance? Does it recognize properly when entering and exiting highways? Is it stable?
عبدالرحمن رضوان
عبدالرحمن رضوان2024-09-03 21:21
Thank you! If you have any content that needs translation or any questions, feel free to let me know.
أحمد صابر
أحمد صابر2024-09-03 11:13
Good to use.
خالد عماد
خالد عماد2024-09-02 20:09
Very useful, can be linked with WeChat and Alipay. 🌹
عيسى نايف
عيسى نايف2024-09-02 03:16
Very stable.
سلمان ليث
سلمان ليث2024-08-31 22:40
Today, I used the built-in feature, and it worked pretty well. It was also easy to activate.
How does the Kia Pegas perform on the highway? Is the chassis stable?
I've driven my father's manual Volkswagen Santana for over 10 years. It's quite durable, performs well on the highway, and the wind noise insulation is decent. It hasn't had any major issues. I'm planning to switch to an SUV to experience driving one. I want to ask T-Cross owners: Is the T-Cross reliable? How is the driving experience on the highway, and what about the wind noise insulation?
Dear fellow car owners, is it necessary to do full car sound insulation for the Vito if it's primarily used for family and for its large space, and only goes on the highway less than 5 times a year? Also, how can I modify the interior for better cost-effectiveness for family use?
I've heard this car handles well. How does it perform on the highway? Is it stable around 130 km/h?
Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
How is the built-in ETC device in the car? Is it reliable? Can any fellow car owners share their experience?
Genesis Genesis G80
Genesis G80AED 154,500 ~ 293,000Gasoline & Petrol
