I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
Comments( 6 )
Regretting it now, the center console doesn't support Bluetooth. I have to download music onto a USB drive, it's like using an MP4 player. I even bought a Bluetooth adapter, but it still doesn't work. Can't read it at all. I'd really like to know who designed this. Did they really save that much by not including Bluetooth? Also, the noise while driving is quite loud. It's unbearable on long drives.
Hey folks, the cigarette lighter below the center console in my Sportage has power, but when I plug in the car charger, there's no response. The charger is good. What's the issue?
I just got the 2021 luxury version of the GV80. I'm wondering if I need to apply a front windshield film and window film. Also, for a dash cam, which type can be hidden without needing wiring? Looking for some expert advice.
4The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
5My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
6I have a basic manual version of the 2011 Touran. The center console only has a radio, and I've been using a Bluetooth adapter through the cigarette lighter to listen to music, but there's often electrical interference noise. I've tried switching 2-3 adapters, but the issue persists. Does anyone have good suggestions? I feel like Android screens priced between 300-500 might not be reliable, and I don't want to spend over 1000 on modifications. How can I use the original car audio system?
7Does anyone know where to replace the cigarette lighter fuse with a key symbol under the center console of the 2016 Grand Cherokee mechanical gear model?
8Where is the cigarette lighter fuse located in the center console of a 2010 Honda City?
9Sure, here you go: 1. For the dash cam and Sentry Mode, can I get a larger SSD? I saw some videos where people used a 1TB SSD and it worked. 2. Is there a specific anti-insect screen for the Model X? Can the one used for the Model Y be used on the X? Should I buy it and bring it for installation during delivery? 3. Can the integrated charging hub used for the Model Y's center console be used on the Model X?
10I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
