Hey, anyone here bought a shooting brake? I'm into the Tasman Blue, flagship 2WD with red interior [smirk]. Go ahead and buy it, if you don't like it, I'll take it off your hands as a second-hand purchase [heart].
With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
4Hey guys, I want to ask, I have 250,000 in hand, and I save 12,000 per month. By around August, I'll have about 270,000-280,000. I'm thinking of buying a SE. Not sure about the price by then. I don't have a wife, kids, or mortgage, and I have about 5,000 left over each month. Can I take a loan to get it? Any suggestions or payment methods?
5Is there no interior trunk release button on the 2016 Red Badge 1.5T Automatic 2WD Luxury model? Can it only be opened from the trunk door? Anyone who knows, please help 🙏
6If you're considering buying another car and your annual usage is around 5,000 kilometers, with a budget of 80,000 RMB, you have several options. Since you like the appearance and interior of the Peugeot 508, you might want to look for a good condition second-hand Peugeot 508 within your budget. Additionally, you could explore other compact or midsize sedans that are known for their style and comfort. Make sure to check the vehicle's service history and condition if you're opting for a used car to ensure a good purchase.
