عبد عزيز محمد
2020-08-23 11:19
Why does the temperature in my Fuga always rise when driving on the highway? I've already replaced the fan module once.
حسين كم
حسين كم2020-08-23 11:31
Well, your fan module has been replaced, and actually, things like your thermostat and similar components should also be directly replaced.
عمر عيسى
عمر عيسى2020-08-23 11:30
If your car's temperature is consistently high while driving on the highway, it's likely that there's an issue with your thermostat. I suggest trying to replace the thermostat.
Is the Bluetooth call volume for the Legacy always very low? I've already turned up the car system and volume... still very low... Is it the same for everyone?
Why does the water temperature rise when going uphill and automatically decrease when going downhill, or when turning on the heater with the air conditioning?
I've been having a headache with my Volvo S80 2.5T. After replacing the radiator, the upper hose has come off three times, and then the lower hose came off once. Does anyone know what could be the reason? The water temperature has been normal, no overheating, and the fan is working fine.
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
Why did all the windows and sunroof open automatically? I've experienced this once.
Why does the engine light keep coming on in my 2017 Kia Pegas automatic? After resetting, it lights up again after driving for a while. I've already replaced the oxygen sensor, but the problem remains.
Does anyone know why the water temperature gauge on the 2020 Jetour X70 with 1.5T engine sometimes shows six bars and sometimes five bars? I've already replaced the thermostat, but it still doesn't work.
Why does the display always show 7.0 liters per 100 kilometers, both on highways and at low speeds?
When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
