حسن اميره
Oct 13
Help! How do I use the cruise control on my Smart 453? Do I still have to keep pressing the pedal? [Facepalm] My Murano allows me to relax my feet. Is it broken, or is it supposed to be like this?
When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
When I put my Smart Forfour into reverse, why does the rear wiper keep running? I checked the wiper lever and it's definitely turned off. Why does it keep wiping when in reverse? Does anyone know what the issue might be?
4I feel like the brakes on the McLaren GT are really stiff. Is it possible to modify them later to make them softer? [Facepalm] After being stuck in traffic for half an hour, my right leg is sore. Also, how do you judge the distance on both sides of such a wide car? Every time I drive on narrow roads, I'm terrified of scratching it...
5I just drove my new 2024 380 Luxury for over 100 kilometers, and I'm feeling vibrations in the accelerator pedal when I accelerate. What could be the issue? Do any fellow car enthusiasts experience this too?
6Fellow car enthusiasts, my GS5's central control screen keeps rebooting. The 4S shop said the main unit is broken and it would cost 6k to replace it. [Facepalm] Has anyone else encountered the same issue? Is it possible to repair it?
7How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
8Does the 2017 model of the Smart have CarPlay? Do I need to connect my iPhone using a front data cable?
9Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
10I'm considering getting a Stage 1 tune for my newly acquired 2024 Porsche Panamera to boost its performance a bit. I know this might affect the warranty. If I wait and do it after three years, would that be okay? Is a Stage 1 tune recommended? Will it affect the car's longevity? I plan to keep this car for quite a while.
