سلمان فاروق
2023-08-14 15:33
Are the two wires in the glove compartment on the passenger side supposed to be there? What are they for?
أحمد رأس
أحمد رأس2023-11-10 19:20
Has the central control screen been replaced? This is usually the cable after replacing the central control screen, and you can plug in a USB drive yourself.
نايف إلياس
نايف إلياس2023-11-10 18:44
USB port
سلمان خضير
سلمان خضير2023-10-27 07:06
I also have two, not sure what they are.
The air conditioning filter in the Accent is typically located behind the glove compartment.
The spare tire compartment always has water in it, what should I do? Is it because the drainage hole is blocked or is it an issue with the wiring of the installed reverse camera?
The air conditioning filter for a 2013 Liana is typically located behind the glove compartment. You may need to remove or lower the glove compartment to access it.
Hi everyone! Does anyone know how to replace the air conditioning filter for the 2019 model? How to remove the glove box on the passenger side? If you know, please let me know. Thanks!
The internet connectivity card in the Mitsubishi ASX is typically located in the glove compartment or near the dashboard.
The air conditioning filter for the 2011 Volvo S40 is typically located behind the glove compartment. To access it, you usually need to open the glove compartment and remove any screws or clips that hold the compartment in place. Once removed, you should be able to see the air filter housing and replace the filter.
How many USB ports does the 2020 T99 have? Is there one in the glove compartment on the passenger side?
Does the 2017 Santana with a 1.4 engine have a loudspeaker on the passenger side? My passenger side got wet, and I'm not sure if there was a loudspeaker there originally.
