أحمد أكبر
2020-10-31 01:23
When driving a 2016 Middle East version of the Fortuner in low-speed 4WD (around 30 mph), I switched directly to neutral and then to high 4WD. After that, the car wouldn't move, and it rolls in P gear. What's the issue? Is it the transfer case or the transmission that's broken? Has anyone experienced the same situation? Thanks.
أحمد مكي
أحمد مكي2020-11-01 17:37
In low-speed four-wheel drive mode, my car does the same thing. Pressing the accelerator a bit more will make it move.
20
عمر ثاني
عمر ثاني2020-10-31 10:13
Try shifting the transfer case to neutral and back twice. If it still doesn't work, the transfer case might not be engaging properly.
عمر ثاني
عمر ثاني2020-10-31 10:10
It's possible that the transfer case hasn't switched to high-speed 4WD. While in neutral, I suggest trying it a couple of times to see if it works.
2
أحمد فارس
أحمد فارس2020-10-31 08:09
Just move it up and down a bit, and it should work.
محمد ابيض
محمد ابيض2020-10-31 05:50
If the car slips even when it's in park (P), it could be an issue with the transmission. It's recommended to have it checked out.
20
Toyota Toyota Fortuner
Toyota FortunerAED 114,900 ~ 175,763Diesel & Gasoline & Petrol
