عبدالله عبد الحكيم
عبدالله عبد الحكيم
Dec 13
What is the tank size of your PHEV? The official spec says 80L. My car can still run 17 km when the fuel warning light is on, and it takes 70L to fill up. How about everyone else's?
Comments( 8 )
سعود هاماوي
سعود هاماوي2024-03-04 09:06
72 liters
وليد عبد العزيز
وليد عبد العزيز2024-01-07 09:02
My fuel gauge light is on, and I can only add 65 liters of gasoline. I don't know how big the tank is, but 80 liters seems like a big difference.
عبد العزيز مرشد
عبد العزيز مرشد2020-11-01 12:58
What's the fuel consumption in liters per 100 kilometers for the 2700 4WD? If anyone knows, please reply, thanks!
عبد العزيز مرشد
عبد العزيز مرشد2020-11-01 12:56
What is the fuel consumption in liters per 100 kilometers for a 2700 4WD?
20
فهد دليل
فهد دليل2020-10-25 17:06
My fuel light came on, and I drove another 40 kilometers before refueling. I only added about 60 liters, and usually, a full tank can last over 600 kilometers.
20
عمر رامي
عمر رامي2020-05-20 00:02
Mine can also only take 70 liters.
محمد عبيد
محمد عبيد2019-12-28 11:35
80 liters is correct. When I first got the car, I added 525.
محمد بشير
محمد بشير2019-12-28 05:40
Official data usually reflects a larger capacity, but in reality, when we're refueling, we can't fill up that much because the pump will automatically stop when it reaches full.
What is the fuel consumption of the Maserati GTS, and how much fuel does it take to fill up the tank?
Why does the official spec say the car has a 65L fuel tank, but I can only fill it up with just over 30 liters?
Why does a 2006 Accent manual consume so much fuel? Filling up the tank for 340 RMB only allows it to run 450 kilometers.
What is the fuel tank capacity of the TRD Adventure edition? The specs say it's 87 liters, but I can only fill up about 60 liters. What's going on?
Just had the 2019 automatic Rapid standard serviced and filled up with a tank of gas, then the engine fault code appeared. Has anyone else experienced this?
What could be the issue if the fuel gauge is empty, you fill up the tank, and it still doesn't respond?
When the fuel gauge still shows three bars short after filling up the tank until the pump stops, what could be the reason?
I bought a second-hand 2011 manual 2.0 GL. According to the specs, the fuel tank is supposed to be 65 liters, but the most I've ever filled is around 48 liters, even after the fuel light came on and I drove another 60-70 kilometers. What's going on here?
I have a 2016 P100D and purchased FSD. The car's computer has already been upgraded to 3.0, but the MCU is still NVIDIA. It should be at least the Atom MCU 2.0 to run FSD. Will the official service provide a free upgrade? Looking forward to it 🤩
The fuel tank of the Venza Hybrid Premium is labeled as 55 liters, but I can't even fill it up to 50 liters. How about everyone else's experience?
Toyota Fortuner
Toyota FortunerKWD 8,700 ~ 15,002Diesel & Gasoline & Petrol
