The gear shift on the 15 Middle East version of the Toyota Fortuner includes 1, 2, 3, 4, 5, and R. Can any expert explain the functions? Thank you. 🙏🙏🙏The gear shift on the 15 Middle East version of the Toyota Fortuner includes 1, 2, 3, 4, 5, and R. Can any expert explain the functions? Thank you. 🙏🙏🙏
حسن شاكر
2023-12-28 09:29
محمد بندك
محمد بندك2024-01-04 08:58
Change the gear knob, it should be a mechanical 4WD gear knob.
عمر نظيف
عمر نظيف2023-12-29 15:26
The new gear lever I replaced isn't working [I need some peace].
You can try the following steps to reset the tire pressure warning light: 1. **Check Tire Pressure:** First, ensure all your tires, including the spare, are inflated to the recommended pressure. 2. **Drive Your Car:** Sometimes, simply driving your car for a few miles can reset the warning light. 3. **Use the Reset Button:** Some vehicles have a reset button for the tire pressure monitoring system (TPMS). Check your owner's manual for its location and instructions. 4. **Disconnect the Battery:** As a last resort, you can disconnect the car battery for a few minutes to reset the system. However, this may reset other settings in your car. If the warning light remains on, there might be an issue with the TPMS or a tire. It’s best to consult a professional mechanic to diagnose the problem.
Possible reasons for the acceleration issue with your 2014 2.5 4WD Renault Koleos could include: 1. Engine issues such as clogged fuel injectors or a dirty air filter. 2. Transmission problems affecting power delivery. 3. Faulty sensors like the mass airflow sensor or oxygen sensor. 4. Exhaust system blockage. 5. Fuel system issues impacting fuel economy and power. It's recommended to have a professional mechanic diagnose the problem for an accurate solution.
You have a 2016 model with a CVT transmission, but you're not sure which version it is. You can usually find this information in a few places: 1. **Owner's Manual**: The manual that came with the car often lists the specific version or trim level. 2. **VIN Number**: Locate the Vehicle Identification Number (VIN) on your car and use it to check online databases or contact the manufacturer for detailed information about your car. 3. **Door Jamb Sticker**: There is often a sticker in the driver's side door jamb that includes details about the vehicle, sometimes including the model version. 4. **Service Records**: Check any service or maintenance records you have for your vehicle, as they might list the specific model version. 5. **Dealership**: Contact a dealership with your VIN number, and they can usually provide detailed information about your car.
The 4-year warranty period is ending at the end of the year. Is it necessary to renew the warranty at the 4S dealership? It seems to cost 3000 per year and includes a few maintenance sessions. Please, friends, share your insights. 🙏
Has anyone in the group experienced this issue with a 2019 Patrol, 4.0 Middle East version, after 70,000 km? When switching between D and R gears, there's a noticeable clunk from the chassis. It drives fine on the road, but when changing from forward to reverse, there's a distinct clunking sound.
1. Is it normal for the acceleration of the HiPhi Z model to be very slow, taking about 10 seconds to reach 100, when the battery is around 15%? 2. Is it normal for there to be noticeable wind noise inside the car when driving at speed? Asking fellow car enthusiasts for some answers. 🙏
Possible reasons why your car might not move when you accelerate could include: 1. Transmission issues 2. Low transmission fluid 3. Clutch problems (for manual cars) 4. Brake system issues 5. Engine problems It's best to have a professional mechanic check it out to diagnose the exact issue.
Dear car enthusiasts, I'm having an issue with my 2013 Sharan. The electric door buttons on the B-pillars of the middle doors have become loose and fallen off. I wanted to buy a pair from Taobao, but the seller asked if I needed "positive touch" or "negative touch," and I'm completely confused. Is there anyone who can help explain? 🙏
For the 2017 Middle East version of the 3.6 Grand Cherokee, the central control system is entirely in English. Is it possible to replace it yourself with a Chinese interface that includes CarPlay? Also, in the past couple of years, the fuel pump often stops automatically while refueling, which is likely due to high fuel tank pressure. How can this issue be resolved?
Toyota Toyota Fortuner
Toyota FortunerAED 114,900 ~ 175,763Diesel & Gasoline & Petrol
