I have a new 2022 2.8 diesel GR version. When the car is cold, there's a noticeable jerk when shifting into reverse. After driving for a while, this symptom disappears. Do you know what might be causing this?
When driving the 2014 Foton Tunland 2.8S 4WD, there is a noticeable humming vibration in the cabin when the alternator speed is below 1600 RPM. However, once the engine speed reaches 2000 RPM, the humming sound disappears. Could any experts advise on what might be causing this issue?
Does your car's transmission have significant jerking? When I shift into reverse, I can hear a noticeable clunk inside the car. Is this a serious issue?
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
4When shifting from reverse to neutral in the 2019 GA6, there's a vibration. What's causing this?
5I have a new 2022 2.8 diesel GR version. When the car is cold, there's a noticeable jerk when shifting into reverse. After driving for a while, this symptom disappears. Do you know what might be causing this?
6Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
7I want to ask everyone, I have a 2022 automatic 86. When shifting from a lower gear to a higher one, there's a bit of a jerking sensation. Is this normal?
8What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
9Does your Jetta automatic also have a noticeable jerk when shifting gears?
10I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
