عبدالله يحيى
عبدالله يحيى
Dec 13
After the light came on, I drove 20 kilometers and then refueled 65 liters. I'm starting to doubt if my fuel tank is actually 80 liters.
محمد بندك
محمد بندك2024-06-26 10:09
The capacity is 80 liters, and when the light turns on, there's about 20 liters left. After the light comes on, you can still drive for about 60-90 kilometers. Running 20 kilometers consumes about 2.5 liters of fuel, so there's about 63 liters left. However, the bottom of the fuel tank isn't flat, and the fuel pump can't extract all the fuel. You can try driving 10 more kilometers after the range display shows 0 before refueling.
Why can I only refuel about 40 liters each time when the fuel gauge light is on?
When is it going to be released? I'm struggling with the 3.5L Highlander! It consumes 20 liters per 100 kilometers!
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
The Check Engine light on my JETOUR X70 with 40,000 kilometers suddenly came on.
How many liters is the fuel tank exactly? I refueled 42 liters after the light came on, and it automatically stopped. Isn't it supposed to be a 50-liter tank?
I bought a second-hand 2011 manual 2.0 GL. According to the specs, the fuel tank is supposed to be 65 liters, but the most I've ever filled is around 48 liters, even after the fuel light came on and I drove another 60-70 kilometers. What's going on here?
I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
What is the fuel tank capacity for the 2016 model? I had about 50 km left and when I went to refuel, the pump stopped at just over 40 liters.
Toyota Fortuner
Toyota FortunerSAR 105,700 ~ 182,160Diesel & Gasoline & Petrol
