The gear is constantly showing in N position. There's no response when shifting to A or reverse gear. Seeking advice from experts. What might be the issue?
Is there a situation where it shifts to neutral by itself when reversing in reverse gear?
Does the original factory condition of the Navara automatic transmission make a sound when shifting into reverse gear?
4My 10-year-old Honda City automatic car has noticeable shaking when I shift into reverse gear, but it's smooth in other gears. Can any expert comment on what might be the problem with my car?
5For a 1.4T manual transmission, at what RPM is it generally best to upshift? Also, if you position the ring below, does it prevent shifting into reverse?
6Hello everyone, today after the car accident, it showed a transmission fault, and the gear can't be shifted from the P position. It seems like it's locked. What could be the problem?
7Why is it making a rattling noise when I put it in reverse gear recently? Can any experts give some advice?
8Gear position not displayed, a constant line, and the reverse radar is not working.
9How to fix the issue of the gear position light not illuminating sometimes for the '21 model Compass when in Reverse (R) gear?
10When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
