Does the Smart Forfour not need window tinting? The glass seems pretty dark.
How many liters of oil does a Smart car need for an oil change?
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
4Hey car enthusiasts, does your KIA Pegas have the rear end wiggle when going over speed bumps or uneven roads while turning? My car is pretty stable at 120 on the highway, but when taking a turn and encountering such conditions, the rear seems to wiggle a bit. I've done the wheel alignment, but it doesn't seem to help.
5Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
6For a 2016 model, does it need a timing belt replacement? At how many kilometers should it be changed? Also, when driving on rough roads, there seems to be a "thud" sound from the suspension. It has just reached 80,000 kilometers now.
7Does the 2021 Fengxing T5 EVO have an auto start-stop feature? It seems like it doesn't, but I'm not sure. I need to change the battery, but I'm not sure if it has the auto start-stop function.
8I have high hopes for Chery cars, but buying one can be disappointing. First, many car companies now offer lifetime free maintenance, but Chery does not. Second, when it comes to window tinting, the dealership tells you that it's outsourced, and you have to drive the car there yourself. Once you arrive, you find out the tint is transparent, which is basically like having no tint at all. If you want better quality tint, you have to pay a few thousand more out of pocket, and the sunroof isn't included either. Other car companies usually provide better quality tint for free. Third, when picking up the car, they inform you about insurance and say that to have "no damage" coverage, you need to spend several thousand more. I just want to say, Chery, can you not make potential buyers of Chery cars feel disappointed?
9Does the 2017 model of the Smart have CarPlay? Do I need to connect my iPhone using a front data cable?
10Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
