خالد موجا بطاقة تعريف
Jul 21
Why do I feel a strong drag when I release the accelerator? Does anyone else experience this? I have a 2024 Forester 2.5 with less than 1000 kilometers. What could be the reason? Looking for advice.
Comments( 12 )
عمر بدر الدين
عمر بدر الدين2024-09-24 22:24
GPF -> Gasoline Particulate Filter
علي زيلاخ
علي زيلاخ2024-09-24 21:43
When the speed is around 21, there is a slight surge forward. If you apply the brakes, you don't feel this sensation.
شعيب عبد العزيز
شعيب عبد العزيز2024-09-24 20:07
It should be the transmission issue. I didn't have this problem before, but now it's showing up at 50,000 kilometers.
حسين جمال
حسين جمال2024-09-11 23:02
I actually experience a dragging sensation when coasting at speeds between 35-20.
سلمان عبد الناصر
سلمان عبد الناصر2024-09-11 16:02
My Haval has 2000 km, and I occasionally feel this too. There's no pattern, just occasionally!
شادي عبدالرحمن
شادي عبدالرحمن2024-09-11 15:34
Naturally aspirated cars are like this. They lack inertia, so when you accelerate, they go, and when you release the throttle, they immediately slow down. My Camry 2.5 is just like that.
عبدالله محمود
عبدالله محمود2024-09-11 02:42
It seems like your speed and gear aren't well-coordinated. Looks like you're not an experienced driver!
سلمان نور الله
سلمان نور الله2024-09-10 23:32
I also occasionally experience this situation. The technician at the 4S shop checked and found no issues; it's considered normal. [I want to be alone]
فهد ق
فهد ق2024-09-10 17:13
I got the 2024 2.5 Flagship in July, and it's currently at 2200 kilometers. I'm experiencing the same issue. When I release the accelerator, there's a noticeable slight braking sensation. However, at speeds of 20-25 km/h, it feels like the brakes suddenly release, making the car lurch forward and glide quickly.
نايف طاهر
نايف طاهر2024-07-22 09:41
It's normal, it'll be fine after the break-in period.
I just bought a second-hand car and after driving it for less than 1000 kilometers, it consumed 2.5 liters of engine oil (it's a 5-cylinder car registered in 2014). I'm not sure if any of you experience this oil consumption. Should I switch the engine oil from Shell 0W-40? What should I do, any advice for a budget-friendly solution?
Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
Hey fellow drivers, just wanted to ask if any of you experience a strong drag when you let off the gas at low speeds, especially around 20 mph? It feels like the regenerative braking in electric cars. Have you guys encountered this issue?
I just bought a Subaru Forester 2.5 naturally aspirated. Is a fuel consumption of 13 with the air conditioning on normal? I would like to ask for advice from experienced users.
If I add a turbo to a 2.5 Forester, can the transmission handle it? Or should I go for a stage 2 tune? The brake pads definitely need to be replaced, but I'm worried the transmission might not handle it, even though Subaru's transmissions are quite strong.
How much would it cost to get a 2017 Grand Cherokee Elite Edition with less than 80,000 kilometers? Can someone with experience provide some guidance?
When slowly accelerating at low speeds, the V60 B4 2024 model experiences noticeable jerking and dragging.
Does anyone experience occasional jerking or strong drag while driving the 2021 Outlander at around 70 km/h? It's like tapping the brakes a few times. Have you encountered this issue?
Recently, the engine start-stop system suddenly stopped working, and I didn't turn on the AC. It's been less than three years and under 30,000 kilometers. Does anyone know the reason?
