عبدالله بدر الدين
2024-10-17 09:07
The nozzle on the passenger side wiper arm that sprays to the right but not on the windshield is likely for cleaning or defogging purposes. To turn it off, you may need to check your vehicle's user manual for instructions on controlling the washer system or consult a professional if needed.
علي مجيد
علي مجيد2024-10-18 10:30
The nozzle for spraying the windshield might be misaligned or there could be debris causing the spray to be crooked. You can try adjusting it yourself, and if that doesn't work, visit a service center.
If you're experiencing a "memory insufficient" message when updating the navigation on your Jeep Renegade, you might need to insert or replace the memory card. Typically, the memory card slot is located in the glove compartment or near the infotainment system. Check your vehicle's user manual for the exact location and instructions.
The windshield washer spray on the Rapid is too coarse and too low, spraying below the wipers. How can I adjust it to be finer and higher?
The timing belt in a Kia Sportage engine typically needs to be replaced every 60,000 to 100,000 kilometers. However, it's always best to check the owner's manual or consult with a professional mechanic for the most accurate maintenance schedule for your specific vehicle model.
Where is the rear glass washer nozzle? It always drips down instead of spraying upwards. 🤔
Which button on the Ghibli can spray the windshield washer fluid? I've tried the wipers, they work, but I don't know how to spray the fluid. Can any fellow car enthusiasts tell me? Thanks!
BYD Song Plus 2.0 Fuel version, the windshield washer fluid doesn't spray out, but after driving for a while, it starts working again. What could be the problem?
The windshield washer isn't spraying water, even though the tank is full. Does anyone know what's going on? Do I need to go to the 4S shop to fix it?
What could cause the 2014 Peugeot 308 to not spray windshield washer fluid? Is it the lever on the right side of the steering wheel that needs to be lifted forward for a few seconds? I can't find the spray nozzles, so I'm considering using a needle to check if they're clogged. Any advice from the experts?
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Subaru Subaru Forester
Subaru ForesterAED 97,125 ~ 115,900Gasoline
