مصطفى أحمد
2024-08-08 19:56
If I add a turbo to a 2.5 Forester, can the transmission handle it? Or should I go for a stage 2 tune? The brake pads definitely need to be replaced, but I'm worried the transmission might not handle it, even though Subaru's transmissions are quite strong.
Comments( 7 )
عبدالرحمن أحمد
عبدالرحمن أحمد2024-09-11 13:15
For an 8-year-old Forester, there's no need to spend more on modifications. It's essentially a utility vehicle. With the money you'd spend on upgrades, you might as well invest in an electric car.
عمر مروان
عمر مروان2024-09-09 15:49
There is a 2.5T SE, and there is also a 2.0T XT.
عمر جعفري
عمر جعفري2024-09-08 08:28
No kidding, if you want to match it, you need to modify the suspension. Other transmissions need to be changed.
محمد حميد
محمد حميد2024-09-04 08:45
The warranty is already gone, so just go for it. If you're really into turbo, you might as well get a used Audi Q5. It has great power, and the older models still come with full-time four-wheel drive.
هكيل فهد
هكيل فهد2024-09-02 22:18
What is the second gear?
حسين بهاء
حسين بهاء2024-09-02 09:09
The natural aspiration mainly enhances basic acceleration, but doesn't provide much improvement. Adding a turbo might be too much for the engine to handle. 😊
عبد العزيز ماجد
عبد العزيز ماجد2024-08-19 14:05
You can check online for modifications to add a turbo to the 2.5 Outback.
