عبد العزيز تكريتي
2024-10-08 23:07
I've got a 2013 Forester and I'm hearing some clunking noises from the chassis. I already replaced the steering rack, but the issue is still there. I'm thinking about changing the shocks next, but the specialist said it's not necessary and that this noise is something the car has had since it was made. Has anyone else experienced this issue? Any advice?
سعود بدر
سعود بدر2024-10-26 21:13
I have the same issue. When I gently press the accelerator below 80 RPM, there's a clanking noise from the chassis, like "da da da." The 4S shop said it might be an issue with the inner cylinder, but I haven't touched that area. It doesn't seem like it's the engine. I went to other repair shops, but they couldn't solve it either.
طلحة عبدالرحمن
طلحة عبدالرحمن2024-10-09 03:01
I also have a 2013 model, and when driving over bumpy roads, it feels like there's no shock absorption at all. It's particularly bumpy, and the chassis makes a clunking noise. I've replaced the shock absorbers and bushings, but it didn't help. Some online say it might be the steering gear issue, but I haven't dared to change it. I asked a mechanic from the previous 4S shop, and he said the car has aged, so it's just like that and not worth the hassle.
Does your car's transmission have significant jerking? When I shift into reverse, I can hear a noticeable clunk inside the car. Is this a serious issue?
I'm considering getting a 2017 GS7. Does this model have any common issues? [shocked][shocked][shocked]
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
Is the engine noise of the 2014 Volvo V60 a common issue? [Crying][Crying] Is it just because the car is getting old? Or is there a design problem with this model? [Shocked][Shocked]
Do you hear a clunking noise when you brake or release the brake while driving your car at low speeds?
I have a 2022 manual version, and I'm hearing a clunking sound when turning at low speeds. What could be causing this??? Any ideas!!!
2018 Peugeot 308 1.6L has a clunking noise when turning the steering wheel. Replaced two shock absorbers and the left strut mount bearing, the noise reduced but it's still there.
Has anyone installed the engine guard for the Forester? Is it necessary to install it?
Subaru Subaru Forester
Subaru ForesterAED 97,125 ~ 115,900Gasoline
