حسين معتمد
2024-09-18 17:48
Does anyone with a 2022 Forester experience a rubbing sound from underneath the car when driving at low speeds with the AC on?
I have a 2021 2.0F1A manual Euro Victory, and when I shift from 2nd to 3rd to 4th gear and accelerate, there's a clicking sound between 1100 and 1400 RPM, like it's low on oil. Does anyone else experience this? Once the RPM reaches around 1500 and the turbo kicks in, the sound starts to decrease. The 4S shop upgraded the ECU, but the sound is still there, whether the AC is on or off.
Is there anyone else whose car makes a slight plastic rubbing sound when turning the wheel to the left?
Does anyone experience a situation where, while driving a manual transmission car at high speed, the RPM suddenly goes up but the speed remains the same?
When driving at low speeds with the AC on, the car, which has over 30,000 kilometers, experiences significant vibrations. This is particularly noticeable when frequently reversing or making turns. The steering wheel, door handle, and seats all vibrate. Everything is normal when the AC is off. Sometimes, when idling with the AC on, there's a loud buzzing sound that feels overwhelming to the ears and head! I always use 95-octane fuel. Have you encountered this issue? How should it be addressed?
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
At extremely low speeds, there's a crisp sound from the relay contact when kinetic energy recovery engages. In creep mode, it occurs just when the brake is applied during low-speed crawling. Without creep mode, it happens when you release the accelerator at low speeds. It's just one crisp sound, coming from near or in front of the pedal. The sound is very faint, and can't be heard with the windows open, music playing, or on a bumpy road. This is with the first launch of the dual-motor. Has anyone else encountered this issue, and can it be fixed?
Does anyone else experience a ticking noise from the B-pillar while driving? That kind of tick-tock sound.
I have a 2022 manual version, and I'm hearing a clunking sound when turning at low speeds. What could be causing this??? Any ideas!!!
Subaru Subaru Forester
Subaru ForesterAED 97,125 ~ 115,900Gasoline
