حسين زيد
حسين زيد
Oct 9
Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
أحمد دين
أحمد دين2024-10-30 07:06
The original brake pads damage the disc, wear out easily, produce a lot of dust, and are expensive.
حسين زيد
حسين زيد2024-10-29 15:03
I replaced the front rotors and brake pads at 45,000 kilometers. It seems like I got tricked, but I noticed the rotors have a ridge on the inside and edges. They said if I don't replace the brake rotors, there might be noise.
عبدالله أبشير
عبدالله أبشير2024-10-17 08:55
Did you change both the front and rear wheels?
عمر مروان
عمر مروان2024-10-17 08:29
My old car is 14 years old and the brake discs have never been replaced, even after 200,000 kilometers.
حسين إدريسي
حسين إدريسي2024-10-16 23:12
Did you replace both the discs and pads? How many kilometers have you driven?
Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
Is it reasonable for the 4S shop to charge 500 RMB to disassemble and dry the area under the seats due to blocked sunroof drainage while still under warranty?
Is it better to buy Cayenne brake pads online or go to the 4S shop?
Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
I did the first maintenance at 3,800 km in half a year, and now it's almost a year with only 6,500 km. The 4S shop notified me for maintenance again. Does everyone do maintenance every six months?
When the vehicle just starts, there's a whistling sound from the front wheels, but it disappears after driving for a while. What's the reason? Could it be that a small stone got into the brake disc?
Hey guys, any recommendations for brake discs and pads for the 2019 model? 😊
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
Subaru Forester
Subaru ForesterKWD 7,400 ~ 9,000Petrol
