سعود صباح
سعود صباح
Feb 27
Will there be mechanical noise when the FJ Cruiser climbs with the rear lock engaged? And will there also be mechanical noise when using the crawl mode for getting unstuck?
Comments( 7 )
عبدالله عدي
عبدالله عدي2022-05-12 19:15
It seems like you haven't provided any content for translation. If you have a specific text related to the automotive industry or any other content that needs translation from Chinese to English, please share it here, and I'll be glad to help!
عبدالله عدي
عبدالله عدي2022-02-20 21:40
Almost none.
حسين سلطان
حسين سلطان2021-02-28 17:21
There is a noise when creeping starts, but it stops after the lock is engaged.
عبدالله داود
عبدالله داود2021-02-28 07:24
Not found.
حسين قنصوح
حسين قنصوح2021-02-27 15:49
You need to check if the gear drive shaft's gear ratio is incorrect.
نور دين عبد العزيز
نور دين عبد العزيز2021-02-27 09:26
It's normal to hear unusual noises during off-roading, which can come from the body twisting, bumps, scrapes, or tire slippage. However, generally, the differential lock shouldn't make any noise.
نايف منذر
نايف منذر2021-02-27 03:06
Under normal circumstances, a car shouldn't make the kind of mechanical noise you're describing. It's likely that the drivetrain might be slipping.
How do you switch between the advanced mode and normal mode of the Phaeton's air suspension? In the advanced mode, is the front lower and the rear higher when parked? [Facepalm]
Does the 2010 FJ Cruiser come with crawl control and dual fuel tanks?
Does the Land Cruiser 4000 have a noise when shifting gears?
At extremely low speeds, there's a crisp sound from the relay contact when kinetic energy recovery engages. In creep mode, it occurs just when the brake is applied during low-speed crawling. Without creep mode, it happens when you release the accelerator at low speeds. It's just one crisp sound, coming from near or in front of the pedal. The sound is very faint, and can't be heard with the windows open, music playing, or on a bumpy road. This is with the first launch of the dual-motor. Has anyone else encountered this issue, and can it be fixed?
Do you all remember the Highlander 2.7L climbing issue back in the day? If the Tahoe had a 2.7L engine, with no models equipped with three locks and none featuring a standard 4WD system, would it also face a climbing issue?
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
For the Prado 120, when choosing a rear lock, should you go for an electric lock or an air lock? If you choose an air lock, you will also need to buy an air pump, right?
Is there anyone else experiencing a buzzing noise when the air conditioner is on fan mode?
Is there anyone who can answer a question: Is the engine noise of the 2024 Prado loud when climbing hills or driving continuously uphill?
Toyota FJ Cruiser
Toyota FJ CruiserKWD 9,000 ~ 13,000Gasoline & Petrol
