سلمان خلدون
Mar 28
The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
Why won't the electric sliding door close properly? I have to press it with my hand to get it to lock.
Is it normal for the trunk to beep a few seconds after closing? The trunk is already locked.
X70 stalls, and after closing the car door, it can't be locked with the remote.
4The FJ keeps showing that the door is not closed. Pressing the lock button makes it beep continuously. Manually locking it works, but it still shows that the door is not closed.
5My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
6Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
7Hey car enthusiasts, have you ever experienced the trunk opening when you press the car key to unlock or lock the car? The sensor works fine for opening and locking the doors! But when I use the key to press the trunk button, it opens. What's going on??
8Why does the car beep three times when starting, like the sound when a door isn't closed properly?
9Does the 2013 Roewe have automatic window closing when locking the car, or can the windows only be closed by holding the lock button?
10How to set up the lock beep for the 2019 MG ZS Global Luxury Edition? The central control is already set to lights and beep, but when locking, only the hazard lights flash without the beep. Tried all the suggestions from Douyin and Baidu, but still can't get the lock beep to work.
