The 2008 US version of the FJ Cruiser typically requires about 5.4 liters of engine oil for an oil change.
What type of engine oil should be used for a 2008 S40?
How many liters of oil does a 1.5T engine need to be changed? Is it easy to do it yourself?
What type of engine oil is typically used for the MG3?
4For the 2016 Vitara automatic two-wheel drive Elite version, it's generally recommended to use 5W-30 engine oil. If you just changed the oil and noticed a one-liter increase in fuel consumption, it might be worth checking if the oil type and specifications are correct for your engine.
5What brand of engine oil is recommended for the 17 Middle East version of the FJ?
6Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
7How many liters of engine oil? How many liters of transmission oil?
8Can I use 0W-20 engine oil for maintaining a Land Cruiser 5700?
9The 2008 US version of the FJ Cruiser typically requires about 5.4 liters of engine oil for an oil change.
10What type of engine oil do people generally use for a newly purchased second-hand 2008 2.0? How often should the transmission oil be changed? Thanks!
