سعود داود
سعود داود
May 22
Hi everyone, when I'm accelerating with my FJ and shifting gears, I notice that the shift from 4th to 5th gear feels more pronounced and abrupt. Is this normal? There are no error codes. It's not noticeable during normal driving, but if I deliberately pay attention to each gear shift, I can feel a slight jolt from 4th to 5th. To notice this, I have to keep the throttle steady without releasing or pressing it more. During the 4th to 5th shift, there's a noticeable abrupt feeling. However, if I ease off the throttle during the 4th to 5th shift, there's no issue at all. Any thoughts or suggestions are welcome. Thanks!
عبدالرحمن معتصم
عبدالرحمن معتصم2024-07-27 10:18
How many kilometers has it been? Is it time to change the transmission oil?
I have a 2014 Haima S5 manual transmission, and it's not running smoothly. During acceleration, it feels jerky and there's a noticeable lag when shifting gears. What's causing this issue? Can any experienced drivers or mechanics help me out? 🙏🙏🙏🙏🙏
Hello everyone, is it normal for my 2013 Mazda 5 automatic to have a noticeable jerk when shifting from first to second gear, while other gears aren't as obvious?
Is it a problem with the gearbox if sometimes the 4th gear won't shift down to the 3rd gear in a 2015 Honda City with a manual transmission? Waiting online for someone knowledgeable about cars to answer.
I have a question. Today while driving, I noticed that the gear shift lever on my automatic transmission can be shifted without pressing the button on the handle. Is this a problem?
Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Is it normal to feel a jolt or a forward surge when shifting gears during acceleration?
When idling in place, the tachometer occasionally fluctuates slightly. What could be the issue, fellow car enthusiasts? On a flat road, when driving in first gear at idle, there is a noticeable jerk. The jerkiness becomes more pronounced when the air conditioning is turned on.
Toyota FJ Cruiser
Toyota FJ CruiserQAR 126,000 ~ 158,000Gasoline & Petrol
