عبدالرحمن برهان
2024-09-28 00:19
Hey car enthusiasts, quick question. When I switch from N to D while idling and press the brake, the car jerks a bit. It's a new car, is this normal?
عبدالله ماجد
عبدالله ماجد2024-10-06 21:16
It's normal, traditional transmissions are like this. Both the Prado and Land Cruiser have this characteristic. However, the transmissions in newly produced cars are all computer-controlled, so this doesn't happen anymore.
علي سعد
علي سعد2024-09-29 23:06
Oh my God, isn't it normal logic that there should be power output when shifting from neutral to drive?
Is it normal for the RPM to increase by 100-200 when shifting the FJ from D to N, and then continue to maintain the increased RPM?
When the car is in D gear at idle, it feels weak (like an ant crawling), but when you press the accelerator, it becomes normal. In reverse gear, it doesn't move at all unless you press the accelerator. The car is a 2016 Haima S5.
When I press the accelerator while the car is stationary, it jerks like a newbie driving a manual car. But if I let it coast a bit after releasing the brake and then press the accelerator, it runs smoothly. Does anyone know what might be causing this? ╮(╯_╰)╭
Hey folks, quick question. Is it normal for a 2019 Toyota Fortuner to make a loud noise when starting, but then it quiets down once the speed hits around 30?
Is it normal for the brakes to apply themselves without pressing the accelerator while driving?
Just a quick question, do you get car sick sitting in the back? My kid tends to get car sick easily.
Hey folks, when starting the car cold and switching from P to D, the transmission makes a clunking sound. Also, when parking and switching from D to P, the car lurches forward a bit. Any idea what's causing this?
