علي منصور
2022-01-03 01:26
Why is the front USB port sometimes powered and sometimes not, even after the 4S shop replaced it with a new one?
Why is the USB port in my Koleos not powered?
Why is the USB in Koleos not powering up? It won't connect.
Why is maintenance at 4S shops so expensive, folks? Can I get maintenance done outside of 4S shops?
Will the 2024 new fuel version of the Mini Cooper be released in the domestic market? Is it already unavailable for order, and are the ones bought from 4S shops just inventory cars?
Should I replace the battery at the 4S shop or do it myself? I'm torn.
How many USB ports does the 2020 T99 have? Is there one in the glove compartment on the passenger side?
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
Can the USB port in the car be used just for charging? Why can't it connect to the car's infotainment system?
Why is the USB on my Song Plus Fuel Version not charging? Will I have to pay if I go to the 4S shop, considering it's still under warranty? If anyone knows, please let me know.
Is the front row of the Asian Lion equipped with USB or Type-C ports?
Ford Ford F 150
Ford F 150AED 199,395 ~ 300,000Gasoline & Hybrid
