Why do the low beam lights on the Ford F-150 Raptor turn on in all gears except for park?
What's the difference between the Ford F-150 and the Raptor? Should I buy the Raptor or the F-150? I'm really torn.
How much is the current markup on the Ford F-150 Raptor?
4Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
5As long as the Ford F-150 Raptor is not in the "P" (Park) position, the low beam lights turn on. What's going on?
6Why do the low beam lights on the Ford F-150 Raptor turn on in all gears except for park?
7How's the 2021 Ford F-150 XLT? It seems less luxurious compared to the Laramie Longhorn, but it's not lacking in features either. It doesn't seem inferior to the F-150 Platinum, plus it has all-terrain (AT) tires. Can any expert shed some light?
8Where is the engine number located on the 2011 Ford F-150 Raptor?
9Suzuki Liana 2013 model! Why do all the lights work except the low beam? Where is the low beam fuse located...
10Hi everyone! Could anyone tell me where the low beam fuse is for a 2013 Liana? All the lights work fine except for the low beam. Does anyone know what the issue might be...?
